Hi !
Is it possible to copy multiple .src files in the Program folder at once using only the pendant ?
There doesn't seem to be a "Shift" key on the virtual keyboard to do a multi-selection.
Thanks !
Hi !
Thanks !
You can select multiple files by using the fingetip and move it from left top to right bottom over the files you want to select.
Hi Hermann,
Actually, it seems to work rather from top-right to bottom-left.
Thanks !
Yes finger tip. It's the same as you can use the mouse in standard windows explorer. You must begin a bit out of the file name. Or connect a mouse and try it with the mouse.
Great ! Thanks.
All that time wasted looking for a "Shift" key...
