does anyone know the system variable which is set when you configure "Multi Program Selection" in System/Config. Or do you know any other way to set this to TRUE with a Karel or TP program?
Thanks in advance
Thanks in advance
I found a variable named $COLLECT_CFG.$MULTI_PROG but it doesn't seem to set the parameter in system/config despite the name
$SCR.$MULSELENB I believe is what you're looking for.
Hey Jupp, thanks, that's exactly what i was looking for, unfortunately it is not documented in the reference manual.
