Fanuc Arc Type Motion Limitations
  • krgaurav22
  • September 14, 2023 at 2:28 AM
  • krgaurav22
    19
    I am working with Fanuc CRX-10iA/L robot. I am trying to move it along an arc with 500mm radius and pitch varying from -15 degrees to 15 degrees. When I put 15 points like below, it works fine. But, when I increase the number of points to more than 15, it throws error: MOTN-356 ARC:180 deg SPIN change(G:1) . I tried different angle ranges, whenever the point count is more than half the angle range, the same error comes up. Is this a limitation from Fanuc ?
    A P[1] 250mm/sec FINE ;
    A P[2] 250mm/sec FINE ;
  • Shellmer
    53
    5
    161
    • September 14, 2023 at 7:49 AM
    Quote from krgaurav22
    It may be a limitation of the motion planner itself, you may need to use the normal circular instruction instead of the arc one.
    But, why you do want to create 15 points if you have a fixed radius?
    If it's because you want to change the minimum and maximum angle of the arc, I suggest you to just calculate 3, or even 5 points along the arc using sin/cos to just rotate the points the way you want. You can do it by calculating the arc points with that fixed radius and then displacing them a fixed distance on XY to the location you want with the rotation you need.
    That's what I am doing right now on an application where I needed to parametrize both the radius and start/end points of the path and it's not difficult, you can do a little function with karel to just pass the angles and storing the points on PR.
    That's is what
  • krgaurav22
    19
    • September 14, 2023 at 5:55 PM
    I am doing 15 or more points because we want to capture some reading on the probe from all of these points which are at the same radius from the origin.
    I will try the normal circular instruction and see if that works.
  • HawkME
    570
    3,270
    • September 14, 2023 at 6:03 PM
    Try adding a wait instruction every 3 points. That might break up the motion planner.
  • krgaurav22
    19
    • September 14, 2023 at 8:09 PM
    I have wait instruction after every point as well, here is a sample of the code:
    5: A P[1] 250mm/sec FINE ;
    6: R[8]=0 ;
    7: WAIT R[7]=1 ;
    8: A P[2] 250mm/sec FINE ;
    9: R[7]=0 ;
    10: WAIT R[8]=1 ;
    11: A P[3] 250mm/sec FINE ;
    12: R[8]=0 ;
    13: WAIT R[7]=1 ;
    14: A P[4] 250mm/sec FINE ;
    15: R[7]=0 ;
    16: WAIT R[8]=1 ;
    17: A P[5] 250mm/sec FINE ;
    So, in my python code, I read the readings from the probe and then update the register R[8] and R[7] alternatively.
  • HawkME
    570
    3,270
    • September 14, 2023 at 8:43 PM
    Can you do a joint move instead of arc?
  • krgaurav22
    19
    • September 14, 2023 at 9:02 PM
    I am going to try that today.
  • krgaurav22
    19
    • September 14, 2023 at 11:14 PM
    I replaced Arc motion with Linear motion, and it works fine.
Similar Threads
  • Circle Arc Type A Motion Instruction
    • MJR
    • November 22, 2021 at 9:13 PM
    • Fanuc Robot Forum
  • arc
  • CRX-10iAl
