I want to set a position register to an updated position from Karel. For an XYZWPR position this would simply use the built-in function SET_POS_REG, however this function ignores the extended axes of an XYZWPREXT position type. Is there any way to be able to set a position register to a position with extended axes?
Imagine I want to use PR[1], then for now I am setting PR[2] with Karel, and then copying axes 1-6 of PR[2] into PR[1]. Then I will manually set PR[1,7] to the desired value, or copy it from a different PR that contains the correct value, but this is not as nice as I figured it could be.
