Hi, I've got a wierd problem with ROBOGUIDE (V9.40). It doesn't load any CAD files (even those from default library). When I try to add any fixture/tool/etc. ztcGfX Error pops up: ".......... is not found, an empty object will be created. Are you sure to make empty objects for other missing files?". I always run it as administrator, I'm working on Windows 11. All the files are there and aren't corrupted. I also tried to move them into different directories (the same with my workcell). Reinstalling ROBOGUIDE also didn't help.
ROBOGUIDE CAD files problem
michald53 -
June 15, 2023 at 1:08 PM -
HawkME
June 15, 2023 at 1:30 PM Approved the thread. -
Lemster68
June 15, 2023 at 1:51 PM Moved the thread from forum General Discussion of Industrial Robots Only to forum Fanuc Robot Forum. -
Just in case, before reinstalling ROBOGUIDE, go to the top menu bar and select TOOLS -> Option and go to the General tab. Here are my settings, try to see if there's anything unchecked or checked by mistake.
you should have a ROBOGUIDE Installation Support .docx file in the Support/Troubleshooting ROBOGUIDE folder of the download folder for ROBOGUIDE(not the install folder on your C, but the SFTROBOGxDVD...) folder.
That docx has some info on this issue
I ran into this before and FANUC pointed me there which is why I know about iit
Mine are exact same Reinstalling didn't help
I ran into this before and FANUC pointed me there which is why I know about iitI can't find the
Could you please send me the .docx file? I don't have it in the downloaded folder.
Too bad, I think this file is missing.
But it's strange that in instalation it didn't put the file.
I've figured it out guys. The problem was that i had a letter from the polish alphabet im my windows user name.... Thanks for the help anyways!
The problem I think is with non-english PC systems. Make sure in the CAD library explorer, the path is something like "C:\ProgramData\FANUC\ROBOGUIDE\Image Library" or similar, without any special characters that make it not recognise the path where the CAD files in the "csb" format.
