If you are using a tablet you should make sure you have the latest version of tablet tp.
Fanuc CRX - Could Not Turn Servo On
ROBOT_G -
June 11, 2023 at 10:37 PM -
if your robot is new call fanuc and have them send service tech out its covered under warranty.
open the robot in Boot Mode (swipe in from the left side of the screen and select Boot Mode) and power cycle, then perform an INIT start from this menu.
That would reinit the robot to factory settings. This would rule out software
You will lose and programming you have done to this point on the robot
