E1394 : Cannot Reset Conveyor Value In Conveyor Synchronous Motion (Work1), (JT7)
Program = autostart3.pc Step=4.
ZX165, robot material handling robot while picking the robot hanger from Conyer robot get fault kindly help out. thanks for advance.
If the autostart3.pc is stopping and producing that error, then you need to look at autostart3.pc data and find out why.
Kindly help out here attached AutoStart pc pg.
PROGRAM autostart.pc() #0;SIGNAL
100; START
IF SIG(1017) THEN ;HAND CLAMPER1 UNCLAMP END
SIGNAL 65
ELSE
SIGNAL -65
END
IF SIG(1018) THEN ;HAND CLAMPER1 CLAMP END
SIGNAL 66
ELSE
SIGNAL -66
END
IF SIG(1019) THEN ;HAND CLAMPER2 UNCLAMP END
SIGNAL 67
ELSE
SIGNAL -67
END
IF SIG(1020) THEN ;HAND CLAMPER2 CLAMP END
SIGNAL 68
ELSE
SIGNAL -68
END
IF SIG(1021) THEN ;OHC HANGER UNCLAMP END
SIGNAL 69
ELSE
SIGNAL -69
END
IF SIG(1022) THEN ;OHC HANGER CLAMP END
SIGNAL 70
ELSE
SIGNAL -70
END
IF SIG(1023) THEN ;HAND IN7
SIGNAL 71
ELSE
SIGNAL -71
END
IF SIG(1024) THEN ;HAND IN8
SIGNAL 72
ELSE
SIGNAL -72
END
IF SIG(1025) THEN ;HAND CLAMPER1 HANGER CONFIM
SIGNAL 73
ELSE
SIGNAL -73
END
IF SIG(1026) THEN ;HAND CLAMPER2 HANGER CONFIM
SIGNAL 74
ELSE
SIGNAL -74
END
IF SIG(1027) THEN ;OHC CLAMPER HANGER CONFIM
SIGNAL 75
ELSE
SIGNAL -75
END
IF SIG(17) THEN ;HAND CLAMPER CLAMP
SIGNAL 81
ELSE
SIGNAL -81
END
IF SIG(18) THEN ;HAND CLAMPER UNCLAMP
SIGNAL 82
ELSE
SIGNAL -82
END
IF SIG(19) THEN ;OHC HANGER CLAMP
SIGNAL 83
ELSE
SIGNAL -83
END
IF SIG(20) THEN ;OHC HANGER UNCLAMP
SIGNAL 84
ELSE
SIGNAL -84
END
IF SIG(21) THEN ;SOL5
SIGNAL 85
ELSE
SIGNAL -85
END
IF SIG(22) THEN ;SOL6
SIGNAL 86
ELSE
SIGNAL -86
END
IF SIG(23) THEN ;SOL7
SIGNAL 87
ELSE
SIGNAL -87
END
IF SIG(24) THEN ;SOL8
SIGNAL 88
ELSE
SIGNAL -88
END
; MOTER POWER ON
IF SIG(33) THEN
SIGNAL 1
ELSE
SIGNAL -1
END
; HOME POSION
IF SIG(41) OR SIG(48) THEN
SIGNAL 2
ELSE
SIGNAL -2
END
; CLAMPER UNCLAMP END
IF SIG(1017) AND SIG(1019) THEN
SIGNAL 3
ELSE
SIGNAL -3
END
; FAULT RESET
IF SIG(1002) THEN
SIGNAL 40
ELSE
SIGNAL -40
END
; AUTO RUNNING
IF SIG(34) THEN
SIGNAL 6
ELSE
SIGNAL -6
END
; SIGNAL TOWER(RED)
IF SIG(1036) THEN
SIGNAL 5
ELSE
SIGNAL -5
END
; TEACH MODE
IF SIG(37) THEN
SIGNAL 4
ELSE
SIGNAL -4
END
GOTO 100
.END
.PROGRAM autostart2.pc() #0;WORK SPACE
100; START
IF SIG(49) THEN;
SIGNAL 2001,-2002,-2003,-2004
TWAIT 1
END
IF SIG(50) THEN;
SIGNAL -2001,2002,-2003,-2004
TWAIT 1
END
IF SIG(51) THEN;
SIGNAL -2001,-2002,2003,-2004
TWAIT 1
END
IF SIG(52) THEN;
SIGNAL -2001,-2002,-2003,2004
TWAIT 1
END
pc_01 = TASK(1001)
pc_02 = TASK(1002)
pc_03 = TASK(1003)
TWAIT 0.02
IF (pc_01+pc_02+pc_03)==3 THEN
SIGNAL 45
TWAIT 1
GOTO 200
ELSE
SIGNAL -45
TWAIT 1
GOTO 200
END
200;
GOTO 100
.END
.PROGRAM autostart3.pc() #0;FLC ENC RESET
100;START
;;CV ENC RESET
IF SIG(1040) THEN; FLC ENCODER RESET 1
CVRESET 7
; PRINT "JT7 RESET!"
TWAIT 1
PULSE 98,1
WAIT SIG(-1040); FLC ENCODER RESET 1 SIGNAL OFF
END
GOTO 100
.END
Usually this error is produced when you try and reset the conveyor position whilst the robot is in motion.
In your autostart3.pc you are scanning for input 1040 in order to reset the conveyor position to 0.
1. What is sending this signal to the robot.
2. What is the main motion program segment executing when this signal is being sent.
