  4. Stäubli & Bosch Robot Forum
Staubli RX60bl CS8, Arm power shutdown
  • 56789Name
  • February 15, 2023 at 9:29 PM
  • 56789Name
    Hello to all,
    Hope someone will answer.
    We bought a Staubli robot RX60 with CS8 controller 1 year ago, about 10 days ago we started getting message on Pendant: "Arm power shutdown: internal power error (CS8: 24V2, CS8C: ALIM_OK in ARPS module). Reboot is needed to recover".
    I don't know how I should do a reboot in this case, also I opened central panel measured power on 24_V2 and is 25,2 volts.
    Did someone get some idea what can be an issue?
    Picture attached.
    Images
      • 131.25 kB
      • 900 × 1,200
      • 10
  • ElEsgalho
    17
    119
    • February 22, 2023 at 4:26 PM
    24V2 is related to the arm power ON/OFF,
    Are the LED on the ARPS ok?
    If the light is not coming ON on arm power this could mean you have a problem with the brake release signal.
    When did this start to happen? When this happens is the robot moving? Any specific position of the robot?
  • ElEsgalho
    17
    119
    • February 22, 2023 at 4:27 PM
    Furthermore, please look at the 24V2 electrics:
    Can you measure it?
  • Intec
    • November 16, 2023 at 6:26 PM
    Hello. Did you ever resolve this issue? Arm power shutdown: internal power error (CS8: 24V2, CS8C: ALIM_OK in ARPS module). Reboot is needed to recover. We started getting this issue and are looking for the solution.
    Thank you in advance.
  • POWER
  • arm
  • shutdown
  • cs8 RX60
