Robot turns on, and seems to be communicating with welder. there is no indication lights on the power wave. There were two boards replaced. welder seems to be stuck on high like a plasma torch.
Does Arc link need to be reestablished?
What kind of Controller/Power Supply are you using? Also what kind of welding process are you using?
Arc Mate 120ib
R-J3IB controller
Power Wave455m/STT, but the nothing is connected to the third stud so I don't believe we are using the STT weld process.
There is a sense lead connected to the POS.
We are welding in Mig.
Robot Burt up. Had to replace the control board and the Digital power Pc board.
I was thinking Arc link may need to be reestablished due to the boards?
I cannot control current. I can feed wire though from the pendent.
