  4. Adept Robot Forum
Frame function
  • nimius83
  • February 7, 2023 at 12:26 PM
  • nimius83
    18
    Hello everybody,
    I would like to replicate the function "Frame" on other robots, like Kuka.
    SET pallet = FRAME(loc.origin, loc.x.axis, loc.pos.y, loc.origin)
    The new frame pallet has a different orientation than loc.origin, loc.x,axis and loc.pos.y (let's suppose these 3 points has the same orientation Rx,Ry,Rz)
    This difference can be calculated as: SET dif = INVERSE(pallet) :loc.origin
    Then, I can move on the pallet:
    SET pick = pallet:TRANS(0*x.distance, 2*y.distance):dif
    What I don't understand is why the frame pallet comes out with a different orientation, even though the 3 points have the same orientation between them.
    Do you have any idea?
  • SerVas
    7
    • June 19, 2023 at 12:44 PM
    you can find very good and sipmle explanation of FRAME function by Kawasaki Youtube Channel:
    External Content youtu.be
    The AS language is very similar to V+. Just consider instead of "SET" in V+ it is "POINT" in AS, instead of ":" in V+ it is "+" in AS and instead of "INVERSE" it is "-" (MINUS) in AS.
  • TygerDawg
    187
    • June 21, 2023 at 4:55 PM
    It has been many years since I was deep into V+ language, but something doesn't seem correct with your code. Perhaps. Maybe. Possibly.
    Your method of calculating and using the INVERSE transform dif bothers me for some reason, and I cannot discern why (too many years ago). :sleeping_face:
    Establish a frame (user coord sys) in space with
    SET pallet = FRAME(loc.origin, loc.x.axis, loc.y.axis, loc.origin)
    This assumes that you taught the three frame locations properly (and taught with an accurate tool):
    • loc.origin is at the ORIGIN of the new frame
    • loc.x.axis is ON the X-AXIS of the new frame
    • loc.y.axis is somewhere in the positive X-Y plane of the new frame (not required to be ON the Y-AXIS of the frame, but is nice if it is)
    • fourth argument defines the location of the new frame origin
    • orientation of the three frame location points is irrelevant, only X, Y, Z are used to calculate the frame
    Do all of that, then your command to calculate a point relative to the new frame pallet is:
    SET pick = pallet:TRANS(x_offset, y_offset, z_offset)
    BUT it is critical to recognize that the new point pick has the orientation of the new frame pallet. That is, if your frame pallet Z-AXIS is pointing UP (e.g., towards the ceiling) and you desire to have your gripper Tool Coord Sys Z-AXIS pointing DOWN to the workpiece (e.g, towards the floor), then you must reverse the orientation.
    SET pick = pallet:TRANS(x_offset, y_offset, z_offset):TRANS( <either RX = 180, or RY = 180> )
    If frame pallet is taught with foresight, then the pallet Z-AXIS is pointed the direction you need for the tool Z-AXIS, you just have to adapt the X, Y, Z offsets to match your physical position.
    TygerDawg
    Blue Technik
    http://www.bluetechnik.com
Similar Threads
  • Program transfer
    • Chardafon
    • July 13, 2022 at 1:51 PM
    • Fanuc Robot Forum
  • Vision Programming NiryoOne
    • astabc34
    • June 6, 2022 at 9:39 AM
    • other Cobots
  • What is KRC2 doing when you set an array of frame equal to a single frame?
    • mjnewsum
    • February 22, 2021 at 10:00 PM
    • KUKA Robot Forum
  • Cartesian impedance creating offset
    • Just Me
    • December 23, 2020 at 3:28 PM
    • KUKA LBR IIWA
  • kuka robot needs to wait for an input to be on for a certain amount of time
    • n_makin
    • December 3, 2019 at 1:34 PM
    • KUKA Robot Forum
  • FrameDistanceCondition
    • Radicz
    • February 18, 2020 at 8:25 AM
    • KUKA LBR IIWA
  • Vehicle Zero Coordinate - Robot Base Reference Set Up
    • darek8711
    • September 29, 2019 at 7:49 PM
    • General Discussion of Industrial Robots Only
  • Create User FRAME
    • balrog
    • May 9, 2019 at 12:30 PM
    • Manuals, Software and Tools for Kawasaki Robots
  • frame
  • dif
