  3. Cobot Help and Discussion Center
  4. Universal Robots
Incorrect robot mounting, check installation
  • RustyRad
  • December 14, 2022 at 3:42 PM
  • RustyRad
    I am trying to get a UR 5 CB3 cobot running and having difficulty. I can move the robot in low level control without a problem, but when trying to initalize the arm it throws an "Error! Incorrect robot mounting, check installation!" and leaves the robot in idle. Everything appears to be fine in the installation file, but I am not sure on the "mounting". It is floor mounted, but should the angle be 0 or 180? It seems this angle is where it is failing, but I don't know enough here. Can someone help shine some light on this issue or redirect me to a resolution?
  • RoboUser123
    7
    • December 15, 2022 at 11:35 AM
    Generally 0deg indicates floor mounting.
    You could try setting it to 0deg and see if it fixed you problem.
