Stupid Question - FANUC I/O
  • nutcase511
  • November 22, 2022 at 3:31 PM
  • nutcase511
    10
    27
    Good morning everyone,
    I have (hopefully) a stupid question.
    We bought a used robot, an M-410iC/140HL that was previously used to palletize boxes.
    We are using it for the same purpose, but I have a challenge setting up the I/O.
    Previously, they used EthernetIP to communicate with the robot/cell/PLC, and I'm removing all other devices except the robot for the current application. Inputs and Outputs 1-256 are assigned for EthernetIP.
    For whatever reason, I cannot get the robot to let me add another range of inputs or outputs as Digital I/O into the mapping.
    I've tried doing a controlled start, numerous power-cycles.
    My main question - is there a system variable to set the number of I/O showing in the mapping scheme? I'm wondering if they limited that to 256, so that no other parts of the range show up. If I delete the EthernetIP from the mapping, will that allow me to then add in the digital I/O? I'm planning to use a FANUC backplane and 16-point digital Input and Output cards inside of the controller to do things like turn vacuum pump on and off for the EOAT suction cups, receive UOP start/reset signals from a control box located away from the robot, and an auxiliary signal set from some safety scanners (I can handle the external e-stops, fence open signals)
    Please help! Hopefully I'm just overlooking something stupid, but can't find any good info in my manuals.
    -nutcase511
  • nutcase511
    10
    27
    • November 22, 2022 at 4:58 PM
    Update for everyone:
    Under System Variables, $MAX_NUM_PRT was set to 256, I changed to 512.
    Once I changed the first set of EthernetIP to range 1-15, then I was able to add more parts of the range.
    Numerous reboots required to update everything.
    Because they had previously used a lot of the I/O for UOP signals and status Outputs (product dropped, robot running, crash detected, etc), I had to separate the second Input card to range 200-215.
    A little convoluted, but I thought I'd give an update. Everything working now (though a little messy)
    Edited once, last by nutcase511 (November 22, 2022 at 10:07 PM).
  • pdl
    268
    1,524
    • November 22, 2022 at 6:29 PM
    The number of digital I/O points is normally set under program limits setup under a controlled start:
    As to your other issues, is $IO_AUTO_CFG set to true?
Similar Threads
  • Frame data from backups?
    • SkyeFire
    • July 9, 2020 at 3:22 PM
    • Fanuc Robot Forum
  • Inertia units: Payload Checker vs Robot (kg*m*s^2 vs kg*cm*s^2)
    • SkyeFire
    • March 11, 2021 at 4:51 PM
    • Fanuc Robot Forum
  • Strip Chart Recorder function?
    • SkyeFire
    • May 6, 2021 at 10:07 PM
    • Fanuc Robot Forum
  • 25-300-25 Specs?
    • gpunkt
    • March 9, 2021 at 4:44 PM
    • Fanuc Robot Forum
  • fanuc R-J3iB with Cognex INsight 8000 - Modbus or DeviceNet
    • MikeWestwood
    • October 20, 2020 at 12:27 AM
    • Robot Vision and Vision Products
  • Transformation of existing programs, inline forms correction
    • Crmo
    • April 27, 2020 at 6:25 PM
    • KUKA Robot Forum
  • R-30iB Plus fan noise
    • SkyeFire
    • February 10, 2020 at 4:02 PM
    • Fanuc Robot Forum
