It has been so long that I forgot how to reset the encoder (T axis) on a MRC K6. I can not find it in my notes. Any help would be appreciated.
Thanks in advance.
Jeff
Thanks in advance.
Jeff
On the encoder plug you short zero volt and rst. If the encoder connection does not have labels on the wires, you have to look closely at the plugs. For this motor there should be two plugs for the encoder, one white, one red. On the red connector, short 2 & 6 (see picture attached). You may have to keep it shorted over night to get the encoder to reset.
Thank you so much. I will try on Monday (the robot is actually sitting 2 hours away). The robot sat for 2 months disconnected from the control. All the axis showed up in error at first, but cleared after being powered for a few minutes, but this one. I remember having this many years ago and resetting the axis did the job (as I recall).Thank you once again.
