R30iB - How to edit String options in context menu of arguments?
  • BrainKaput
  • April 5, 2022 at 12:26 PM
  • BrainKaput
    27
    As the subject says.
    When calling a TP program and adding arguments to it. If you choose String it shows up a context menu with options which if you select them they automatically add that string.
    Is there a way to edit these strings?
    Thanks!
  • HawkME
    568
    3,268
    • April 5, 2022 at 7:30 PM
    When you choose string, then it will show some options. Ignore that. Instead if you press F5 it will pull up another menu and you can select Options/Keyboard, then F5 for keyboard.
    Then type in whatever you want.
  • BrainKaput
    27
    • April 5, 2022 at 10:24 PM
    Quote from HawkME
    Yes, I know how to type in the string. The thing is I use a string argument for some options inside the program. (e.g.: A, B, C,.. )
    So, it would be nice to have those options in the context menu instead of the need to type them.
  • HawkME
    568
    3,268
    • April 6, 2022 at 8:08 PM
    You can use the Argument Wizard.
    It is in the manual under "Wizard to input arguments". You have to type up a text file that is a definition for the arguments and then save it with a ".dt" extension and load it onto the robot.
    You can define a list of predefined strings that the person can chose from on a list, among other things.
  • r30ib
  • strings
