ABB S4C+ Won't Boot: Infinite Count-Up on Teach Pendant
  • Good morning! Hopefully you all can provide some guidance, and thanks in advance.
    We had used an s4cplus controller for some years without issue, then had an overheating issue about 2 years ago. We ended decommissioning this robot at the time, but would like to see if we can replace parts and get it back up and running.
    Upon boot up (no robot attached), we see that the Teach Pendant has an infinite countup "Wait! Startup in progress. -->". After reading in some of these forums, here is some (hopefully) helpful information for troubleshooting:
    LEDs:
    Power Supply: Green
    On the DSQC 509
    En: Nothing
    MS: Red
    NS: Nothing
    DSQC 504
    Nothing
    DSQC 327
    MS: Green
    NS: Nothing
    CPU
    PWR: Green
    HDD: Nothing
    Status: Flashing green
    After connecting via hyperterminal:
    /// Bootloader 1.1/8 Nov 24 1999, 00:20:32 ///
    disk 0:0 ATA STI Flash 6.1.0
    disk 0:1 unknown type
    done.
    system: '/hd0a/24-27344'
    release: '/hd0a/3HAC6811-1.94'
    Loading module /hd0a/3HAC6811-1.94/bin/mc 9204856 + 653832 + 5462212
    Loaded configuration /hd0a.mc.cfg
    Loaded configuration /hd0a/3HAC6811-1.94/mc.cfg
    Starting at 0x108000...
    Starting RTC synchronization of system time...
    /hd0a/ - Volume is OK
    Phys mem : 0x3eff000
    Perm pool : 0x8e4c20 @ 0x361a3e0
    LocalCA mem : 0x18000 @ 0x88000
    LocalSM mem : 0x8000 @ 0x80000
    Local mem : 0x361a3e0
    BSP version : 1.1/15
    Creation date : Feb 24 2002 13:48:25
    Main network : fei0 XXX.XXX.X.XX 00:00:60:da:71:53 (I left out IP address from this transcription)
    Executing startup script /hd0a/3HAC6811-1.94/bin/mc.bat ...
    mRouteAdd "XXX.XXX.XXX.XX". "XXX.XXX.XXX.X", 0xfffffe0,0,0
    value = 0 = 0.0
    taskSpawn "root",100,28,40000,root_entry
    value = 55335832 = 0x34c5b98
    Done executing startup script /hd0a/3HAC6811-1.94/bin/mc.bat
    image_restroe: 2367ms
    Page Fault
    Program Counter: 0x0092300b
    Status Register: 0x00010202
    Error Code: 0x00000000
    Task: 0x361a248 "tRootTask"
    Page Fault
    Program Counter: 0x0000001f
    Status Register: 0x00010246
    Error Code: 0x00000002
    Task: 0x351a5c4 "tNetTask"
    I tried to use the instructions to delete the image.bin file and reboot, but with no luck. I couldn't get the prompt to pop up, even after hitting enter. So I would type and hit enter and nothing would happen except it would go to a new line (but no execution).
    Given this info, I would suspect I need to replace the DSQC 509 board, but would love some opinion/confirmation before doing so! Additionally, do I need a functional robot hooked up to allow for the bootup to occur?
    Thanks a bunch and let me know if there's any further information I can provide to help troubleshoot :) .
