Does anyone know how I can connect a push butten to the motor power on switch on the interface pannel for a D43 controller. I have been trying many thing to let this work....
On the forum I found a similar request on a C controller (See link). I have been trying to follow this guide for the D controller but I can change the singal to a higher number. I gives the range [1001-1032] while my interface button gives the range [1-32] [2001-2256]
Post
Re: Kawasaki C-Controller Motor Power "ON" from TP....HOW to do
Simplest way would be to assign a motor power button to the I/F Panel if you are not using the dedicated input for EXT MOTOR POWER ON function and link with the dedicated output for motor power too.
You could go OTT and then have a specific background task to monitor and control it for certain conditions etc.......
Aux 111 - Dedicated Input Signals
- If you are not using EXT MOTOR POWER ON - then allocate this input to a software signal not being used eg. 2254
Aux 112 - Dedicated Output Signals
kwakisaki
Thanks for your help
