Hi, I need your help,
When I usually make the program for our robot and for example have to mill a circle, I often use 4 points and then use Motion MOVC to get
The robot to make a circle.
Is it possible to make a more advanced code / step on the DX200 pendant, where you tell the robot
That it should go from one point and out to another point and keep moving around in a circle where it moves by 3 mm for
each turn until it reaches the extreme point there been set, as I have tried to describe in the picture below.
Best Regards Stig
