Kuka KSS02858
  • lorenzo369
  • September 27, 2021 at 2:46 PM
  • lorenzo369
    Hello to everyone,
    I have an EtherCAT communication with an EL6692 between my software and the Kuka robot, nothing incredible.
    In the past, using same hardware, when I was closing my software I always had these errors in SmartPAD (see left of image below).
    These yellow errors are ok, but now I am working with same configuration on another robot that should be almost same, but I am receiving the following errors (see right of image below) when I am closing the software.
    There is a way/flag/variable/system variable to disable the red error? the red error is not good because it needs a confirm, while the yellow errors are fine because the simply disappeared when I reopen the software. Thank you in advance
  • Ben014
    5
    32
    • September 27, 2021 at 9:08 PM
    Select auto reset after error would solve your problem.
  • lorenzo369
    • September 28, 2021 at 9:43 AM
    Quote from huythai
    Thank you for the suggestion, but this does not work, I always have kss02858 error when closing software
Similar Threads
  • Communiction between Omron PLC (NX1P2) and Kuka KRC4
    • Henrique24
    • February 28, 2019 at 10:32 AM
    • KUKA Robot Forum
  • KUKA Workvisual DTM Catalog, missing device
    • doubravacek
    • August 7, 2019 at 12:52 PM
    • KUKA Robot Forum
  • EtherCAT
