  3. Cobot Help and Discussion Center
  4. KUKA LBR IIWA
Workbench opening safety issue.
  • beeq93
  • July 29, 2021 at 9:39 AM
  • beeq93
    First i would like to say HELLO to all of You, as it is my first post here.
    I've got an problem with workbench for kuka iiwa.
    I started the new project, by downloading it from controler
    When i try to open safetyconfiguration i've got an error. "Could not open the editor: An unexpected exception was thrown."
    Details of this error looks as follow
    java.lang.NullPointerException
    at com.kuka.safety.configuration.model.SamUserSettingsModel.loadWorkpieceData(SamUserSettingsModel.java:502)
    at com.kuka.safety.configuration.model.SamUserSettingsModel.<init>(SamUserSettingsModel.java:249)
    at com.kuka.safety.configuration.eclipseplugin.editors.MultiPageEditor.loadModel(MultiPageEditor.java:808)
    at com.kuka.safety.configuration.eclipseplugin.editors.MultiPageEditor.createPages(MultiPageEditor.java:305)
    at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:348)
    at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
    at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
    at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
    at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
    at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
    at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
    at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
    at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
    at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
    at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
    at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
    at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
    at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
    at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
    at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
    at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
    at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
    at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
    at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
    at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
    at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
    at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
    at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
    at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
    at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
    at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
    at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
    at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
    at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2764)
    at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
    at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
    at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:355)
    at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:164)
    at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:249)
    at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:228)
    at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
    at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
    at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:376)
    at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.java:538)
    at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
    at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
    at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
    at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
    at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
    at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
    at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
    at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
    at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
    at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
    at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
    at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
    at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
    at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
    at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
    at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
    at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
    at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
    at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
    at java.lang.reflect.Method.invoke(Method.java:597)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
    at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
    Do u guys have any ideas how to fix that?
    I didn't try to reinstall workbench, because it takes 2 days in my company to install anything...
    BR
    Krystian
  • Cwany
    53
    • July 30, 2021 at 1:11 AM
    Which version of Workbench/OS?
    Are you using Windows 10 on your PC?
    I have had a few issues with Sunrise.Workbench not running correctly when it was not installed properly. From my experience, a simple mistake made the whole software crush. e.g.:
    1. When installing, make sure the path is short. Also keep the names of the options short.
    2. Install as administrator
  • beeq93
    • July 30, 2021 at 9:57 AM
    Thanks for Your replay.
    The problem was caused by wrong workbench version. I tought it is compatible backwards but it isnt.
    I found correct version, same as my OS and it works fine.
  • iiwa
  • r800
  • sunrise
  • workbench
