Anyone have any ideas as to why the part towards me fuses fine with no filler and doesn’t leave any cracks 8/10, whereas the part on the far side leaves a crack every single time with no filler, seems just about the same clearances/tolerances, really odd. Any input would be appreciated. Trying to weld both in the same program rather than setting up a chuck to center a part at a time and using filler.
Tig Weld Crack (no filler)
Chase -
June 23, 2021 at 7:08 AM -
Thread is Resolved
Here’s the part with no crack
Here’s the part with a crack every time.
I suspect they may be just two dissimilar metals that don’t want to join. Even mig welded by hand and tig welded by hand leave a crack after grinded down slightly.
Dissimilar metals seem to cool at different rates. Pre and post heat may help. You may have to add filler designed for this type of application.
If you want some help, you need to give more infos. Which materials?
Well, one is a tube, and the other appears to be a solid rod. That rod will suck up more of the heat than a tube. You have different heat input dynamics. Could be dissimilar metals as well.
Thanks everyone for the help! We took all the pieces to our metallurgist, sure enough the rod had a high lead content, meant for being machined easy, not welded. The tube came back as a low carbon content steel, which is why that had a much easier time fusing to the base plate. The rods registered as 12L14, which are going to be replaced by low carbon steel rods. Thanks again
