IRVISON POSITIONAL DATA OFFSETS
  • Volic82
  • June 14, 2021 at 9:50 PM
  • Volic82
    ok so i have an irvision3dl camera and if i scroll the robot 10 mm in x+ or x- it gives me a 20 mm offset in the vision offset menu
    but also it shows my positional data as moving 20 mm in the irvision menu after i snap and find.
  • SkyeFire June 14, 2021 at 10:14 PM
    Moved the thread from forum General Discussion of Industrial Robots Only to forum Fanuc Robot Forum.
  • HawkME
    568
    3,268
    • June 14, 2021 at 11:04 PM
    You need to correctly set/calibrate your Z height.
  • Volic82
    • June 14, 2021 at 11:09 PM
    I did an automatic grid calibration. and z height was at 400 mm from grid. camera position above part is 400 mm also. i have a 15 mm grid..
    Edited once, last by Volic82 (June 14, 2021 at 11:18 PM).
  • Volic82
    • June 14, 2021 at 11:15 PM
    and please explain what you mean by calibrate z height...
  • HawkME
    568
    3,268
    • June 15, 2021 at 12:39 AM
    Z height needs to be set to the distance from the offset frame to the part surface. If the grid is used as the offset frame then it is simply the part thickness.
  • mosbe
    52
    • June 16, 2021 at 2:59 PM
    As I experienced even if you calibrate it "good" it doesn't work well because you must mess something in calibration (I don't mean grid cal - I mean processing)
    What I found out that you have in fourth tab in grid calibration something like focal distance or something like that, and there is automatic mode - for me I had to change parameters of it to match distance between camera and an object. I did it in 2D but i think it should be similarly in 3D
  • Volic82
    • June 16, 2021 at 3:55 PM
    Hmm interesting
  • HawkME
    568
    3,268
    • June 16, 2021 at 4:59 PM
    There is an option for a single plane or 2 plane calibration. If you choose 2 plane then it should calculate the focal distance for you.
