Problems with touch sensor
  • fabiobm
  • March 30, 2021 at 3:59 PM
  • fabiobm
    Good morning,
    I have a problem with touch sensing, i programmed the source of the piece, using the macro TCH and saving in a variable point, like P61. When i use shift on before the welding point, it shifts my point, if i modify the point to the joint, and simulate again passing the shift, it will be wrong, like 20mm far the joint.
    Controller: DX100
    ComArc 4
    Configuration of Macro TCH
    AutoTeach 0=off | 0 | 0, 1-2
    Robot Position 1 | REGIST | Start
    Robot Position 2 | REGIST | Surface1
    Robot Position 3 | REGIST | Surface2
    Search Speed | 150 | cm/min
    Shift variable | 61 | Pvar #
    Search Type | 2 | 1-2
    Rapid Input # | 2 | 1-6
    The angle of the touch and the welding point is the same and the tool is the same.
    Someone knows the reason of the point is always out of my joint?
  • forraz
    • March 31, 2021 at 11:51 AM
    Did you tried with shift On and just then modify the points?
    Hold Interlock and TestStart before Shift on and after it pass it try to modify the points.
  • Boring_robot_guy
    36
    • September 25, 2021 at 9:29 PM
    Are you sure youre teaching the macro correctly?
  • PATROLLING
    24
    • September 27, 2021 at 1:02 PM
    Don't modify the points after the shift. The program should be taught then the TCH added after. If the weld positions are modified the TCH needs reprogrammed. Always modify weld positions with shift off then reteach TCH.
  • Touch Sensing
  • Yaskawa dx100
  • ComArc
