KRC1 teach pendant qwerty keys not working
  • sketola
  • March 24, 2021 at 12:57 PM
  • sketola
    Problem:
    Teach Pendant keyboard stopped working after moving VGA-card and hard disk to an other cabinet and back.
    Display works and also keys around the display, but numbers and alfabets (qwerty) and arrow keys not
    When I press ALT+SHIFT+up arrow from TP, I get error message 1052 KCP: Transmission error --> something from the keyboard reaches the controller?
    Tested with 2 teach pendants, both have the same problem (maybe the fault is not in the TP?)
    Tested with 2 different control cabinets, but moving the VGA-card and hard disk from cabinet to cabinet --> same fault
    Is the VGA-card (X821) faulty? Any other possibility to search for remedy?
    External keyboard works
    KR C1
    GUI V2.2.8
    Core KS V2.38_16
    robot Type #KR15_2 Floor ZH02
    R1Mada V6.7.0
  • MOM
    175
    7
    1,414
    • March 24, 2021 at 2:45 PM
    if you use the "search function" you will find the solution for this problem. It is already mentioned in different threads
  • MOM
    175
    7
    1,414
    • March 26, 2021 at 12:35 PM
    first I have to apologize. I read the reasons for that on this or the german forum.
    I was not able to find them again by using the search function.
    The VGA card onyl provides the video signal; CAN Bus is used to transfer the data from KCP to vxworks.
    Therefore it could be
    MFC1 card
    internal wiring (MFC1) to the connector X19.
    bent, pushbacked pins on X19 or connector of KCP
    could be also a problem with vxworks (not sending the data to the windows side (BOF))
    I would start with the connector on mfc1
  • krc1
  • keyboard
  • x821
