Ola estou com um erro 1302 nx100 conforme vi neste tópico que tinha um probleminha igual tinha até queimado um fusível na placa ntu porém foi consertado e foi analisado a placa e não tinha mais nada queimado porém o erro continua alguém poderia me ajudar
Alarm 1302 NX100
Croquetinho -
December 31, 2020 at 4:03 AM -
AL-1302COMMUNICATION ERROR (SERVO I/O) This alarm occurs if there is a communication error between the servo control board (AXA01) and the power-on unit (NTU01).As a major cause of this alarm, a loose connection is suspected. In rare cases, however, the cause is attributed to a noise interference, defective board/cable, or internal data inconsistency.
Sub Code
1: Communication loop back
2: No interrupt
4: Watchdog timer error5: Command timeout
10:Communication loop back (**: AXA board number of the connected unit)
11: Address matching error
12:Servo I/O communication buffer error (**: AXA board number of the connected unit)
Sabe me dizer se o conector x11 do dx100 é igual do dx200
I don't what to make a blanket statement but probably not, DX100 comes straight out of the controller. The DX200 is a 90 degree connector.
Ok muito obrigado
