Fanuc Arcmate 120ic, Lincoln I400, I am unable to purge gas from the pendant. I can feed/retract wire, so I’m communicating. I can go on power wave manager and purge gas using my laptop. If I dump my original backup in, it works. Problem is I’ve done a lot since that backup. Any help would be appreciated. Thanks.
Gas purge issue
Fuzzdizz -
October 14, 2020 at 4:48 PM -
Could be the DO assigned to Gas Start weld output is also being used somewhere else?
Are the DO and WO the same in current and the backed up version?
I would compare the Summary.dg in the old and current backups and see if there's a difference.
