hello,
i am looking to upgrade my s4c controllers to use usb instead of floppy. i was wondering if i might be able to just insert a regular pci card from a pc into the controller and use that as my usb connection.
thank you.
s4c upgrade to usb
uncle 3m ta3 -
January 18, 2010 at 9:17 PM -
There is a solution,we have a usb drive that replace the floppy drive.please contact me for details...
This is a good device to replace the old floppy drives on ABB Robot controllers. Then you can use SD memories !
Is tested on ABB M2000 and Kuka KRC1 robot controllers.Ariel/
I have been having a problem with reading the file name I created on the robot to the USB. I save a back-up as the date to the USB from the robot, when I pull it up on the computer it shows me P666666-7 on every back-up that I created. When I look at the files through the file manager on the robot I can see all the different dates of the back-ups just fine. Its just on the computer. And I am using the batch program that ABB has loaded on the USB stick before you format it. Any help would be great. Thanks
