I have an ABB IRB1400 robot which does not start due to errors which appear as soon as I start it and here are the fault codes:
There is a bad glare on the screen, difficult to read. Not only that, but also seems to be in French. What I think you have going on is a general stop. You need to check that circuit. On the panel board you need to see both GS1 and GS2 illuminated.
Thank you for your reply,
But I did not understand your answer, currently as soon as I launch the start impulse a fault code appeared (code 20008) and after another fault also appeared (code 20074), have what you can help me for solve this problem
