I have successfully establish Ethernet communications with two micrologix 1400 plcs. The problem I am having is when I set a digital output it goes to both PLCs and set bits in each. Is there a way to make the digital outputs and inputs specific to an IP address. The other option I have is to re-write the micrologix programs and make sure I don't use bits are set that are ment for the other PLC.
Any help would be great with this and thank you.
