FANUC Robot Repeat-ability/Accuracy Issue(s)
  • nutcase511
  • January 23, 2020 at 10:16 PM
  • nutcase511
    10
    27
    Hi everyone,
    I have a relatively complicated question.
    I have an R-2000iB/210F that I've attached an electric router and a 1/4" diameter routing blade to. I also put a Keyence LR-ZB250CP sensor on it. I am using Skip condition commands to search for a rounded "up edge" on a part and then route that part. I am having difficulties with repeatability. Our parts can grow/shrink considerably from cycle to cycle because they're roto-molded.
    Right now, I'm searching at 15 mm/s and the sensor is rated for 10 ms response time, +/- 1 mm, and the robot's accuracy is rated at +/- 0.3 mm. I'm not sure if my parts are actually warping or if there is some lag intermittently between detecting an edge and that's causing some parts to be cut tighter than others. My "bologna" math came back that I should be AT WORST +/- 1.2 mm.
    Has anybody done anything similar to this?:question_mark::question_mark:
    -Brandon
  • HawkME
    568
    3,268
    • January 24, 2020 at 12:34 AM
    I have done similar things. Are you using high speed skip or regular skip?
    Also you say rounded up edge? Rounded edges usually won't be repeatable with a laser sensor.
    Also the robot is not rated for accuracy, that is its repeatability rating. Absolute accuracy would be much worse.
  • TomTom
    49
    • January 24, 2020 at 3:18 PM
    You could try to do the skip both ways (off the part and onto the part) and take the middle. That way even if there is some latency issue going on both errors might cancel each other out. No clue if this makes sense with your rounded edge and sensor type though.
Similar Threads
  • Position Converter - Convert from XYZWPR Rep to Joint Rep and Back
    • Nation
    • November 27, 2018 at 12:18 AM
    • Manuals, Software and Tools for Fanuc Robots (you should look here first before posting)
  • constant touch-up of Fanuc M-10iD after safety gate has been entered
    • EMSSTC
    • April 17, 2019 at 8:01 PM
    • Fanuc Robot Forum
  • Digital Input pattern
    • TexDino
    • March 4, 2019 at 10:23 AM
    • Fanuc Robot Forum
  • In search of questions to ask
    • Aza
    • March 29, 2016 at 11:06 AM
    • General Discussion of Industrial Robots Only
