Hi.
A old colleague got in contact with me this morning regarding the minimum seam bead for tracking to be effective and I was kinda not sure what the minimum is. .What I have gathered through the years is that I normally don't track on anything that have a bead less than 50 mm long because just as the weld is almost over the tracking have started to correct itself and then you are left with miss welding at the start while the middle-to-end weld is moving towards the right location. Center Line tracking specifically.
Does anybody know what is the minimum length of what Weldguide will be able to track efficiently?
Is there any parameters to adjust and make modify the minimum to what you want?
