We have KRC4 8.5.7 HF1 and robot is KR 90 R3100 extra HA. The robot will be used for welding application.
The end customer wants us to write a basic program so that robot can go to homeposition etc.
The routine(s) for the welding will be programmed later on by the customer.
The welding must be in a separate source file (from home to welding start point, start welding, until end of welding).
The customer wants to create for every different workpiece he has to weld a new source and corresponding dat-file.
So as time goes by, more and more src-dat files will be added. These files and the routine for welding inside the src-file will have
a typical naming : f.i. welding1.src, welding2.src, etc.
We should at some place in our main program call this routine in the welding source file.
Normally calling a routine in a program is hardcoded.
Is there any possibility to call a routine based on the content of a string variable (in case of krc4 it will be char-array)?
Char-array will be written manually from kcp or from plc communication, and our main program will then call the routine with the name inside that variable.
Call program indirectly
Plc_User -
October 1, 2019 at 1:20 PM -
AFAIK, calling function by variable is not yet possible in KRL. I've hear there were some changes in KSS 8.5 with programs residing on the drive, instead of RAM; maybe you can load different subprograms with the same name?
Otherwise, look into Directory Loader.
is there an update to this topic?
It is possible to do things like that, but you have to change the method of calling/running programs.
You will not have one main program like f.e. CELL.SRC that runs the whole time.
You have to use robot in EXT mode, and use a PLC, or you have to connect some inputs to outputs of the robot, to control auto extern signal by SPS.SUB.
And you have to create a logic in SPS.SUB that start/stop/cancel/select the appropriate program in conjunction with PLC. With that logic you can start a program with a variable name.
This way in can be done since KRC1.
