What is the difference
PLC is a stand alone software and PMC prgoramable machine control is a part of fanuc software?
Which one is better?
TBH, it depends on the application. Fanuc PMC is for better or worse basically the old GE 90-30 plc, and it hasn't changed much. The pmc is an option to consider if you have very simple control requirements. It is a very limited platform though. If your need is something that can handle barcode reading, string handling or higher order functionality, plc is the way to go. We use both methods in our integration, however the push has been to use pmc less and less due to functionality. What I have found IMO is that few customers understand pmc or have used it. Generally they're familiar with a big name plc and prefer that.
