We just did a memory extension and now were getting Pulse mismatch all axes and Need to apply to DCS param. Guessing we did something wrong. Any help would be great . Thanks
Fanuc memory extension
sbecker -
July 9, 2019 at 5:38 PM -
Sounds like when you changed the memory you lost your mastering counts. Hopefully you have a file backup or the original mastering counts that you can re-enter.
If you have the file backup then reload sysmast.sv. or if you have the mastering counts then enter them in the $DMR_GRP variables. I woulc check to see if the counts are still there first. Once the mastering counts are in, then you can set mastering done variable to true. Then go to the master/cal menu, reset PCA, and calibrate.
After that take each axis to 0 degrees and check that it lines up with the witness marks.
