How do I add more registers in FANUC robot?
Sent from my SM-G975U using Tapatalk
Control start the robot, and when the robot is in controlled start mode, you will be able to increase the number of registers.
Thank you!
Where exactly would I find that under control start?
How do I add more registers in FANUC robot? What variable?
I've merged your post from the general into this thread where you are asking the same question. Don't make multiple posts asking the same question across multiple boards.
Regarding your question, it is under the PROGRAM SETUP menu, which is next under the menu button.
Thank you. I found it after actually doing some looking. Thank you again!
