Hello
I put a welding board in NX100, but I have problem with 24 V communication.
Have someone a guide for mount a welding board in NX100 controller?
The board is JANCD-YEW01-E. Have someone mount this board in NX100?
Tk for replay
welding board in Nx100
rzapo -
June 17, 2019 at 1:17 PM -
Thread is Resolved
NX100 robot originally used the XEW01 cards from the XRC generation. The DX100 started using the YEW01 cards, so NX100 was "skipped" for having an analog card specifically for that generation controller.
To get the NX100 to use the YEW01 card you need a version of software (Version 5.x or higher).
If your software version is lower than 5.0 you will need to have it upgraded. If your software version is higher, check the jumper for 16/17 bit communication. Needs to be set to 17.
