good afternoon, which procedure to adjust the touch screem, I made the change but the points are out ... I need to calibrate
TOUCH SCREM
gomoura -
June 1, 2019 at 9:20 PM -
Welcome to the forum............
Kawasaki teach pendant touch screens are a resistive overlay, there is no calibration needed as there is no 'tracker'.
So if you have to replace it, you need to make sure you have it aligned to the screen correctly.
If you have used a none Kawasaki part (not that I know of any you could use as a replacement) then there may be a risk of mis-alignment.Icons, buttons and the keyboard (IMHO) are not designed for those with big chunky monkey fingers (like me), therefore a stylus or another device (I find a pencil with a built in eraser using the built in eraser) is a good alternative......but not a screwdriver.
I bought an item according to the supplier is original, but is not giving adjustment, some other manufacturers have this adjustment
