Misters, I need some help, I need to edit a program, insert registers to manipulate a palletizing robot. When trying to edit the program a message appear "The program is currently in use". What I must to do?
Thanks.
Thanks.
1. Make sure it is not currently running.
2. FNCT -> ABORT ALL to clear all programs from the call stack
3. Make sure that it is not open in any Background Edit instances
4. Make sure you are in the main window (left it split screen)
Misters, I need some help, I need to edit a program, insert registers to manipulate a palletizing robot. When trying to edit the program a message appear "The program is currently in use". What I must to do?Thanks.
If you're using main program like RSR001 you couldn't edit it until robots is working.
Inviato dal mio Redmi Note 7 utilizzando Tapatalk
If its a background program, you'll need to stop it from running prior to any editing.
MENU, SETUP, BG LOGIC
