We recently had a lightning storm that blew the fuse and virester on the power board. We replaced the components and got the machine started. The current problem is that the Device net board is no longer outputting any voltage to the IO board and the IO box on the arm. We are also getting a IMTP-105 error.
We are planning on replacing the Device net board but i thought that if I post a question on here there may be an obvious gotcha that we need to look into. If the board is not outputting anything does that mean the board is not working? Are there other areas that we should look at as well?
We are running a RJ-2 controller with a 420-iw arm.
