I always assumed that within the POSREG.VR it saved Position Register data and also regular Position data. that does not seem to be the case. How can i transfer my position data to another robot? i do not want to edit one by one all my positions.
Saving Positions
Kyle0588 -
May 1, 2019 at 2:49 PM -
PosReg only contains the PRs. If you want program specific points, you have to load that program into your other robot.
Positions P[ # ] are local to the program that they are taught in. If you have the program LS file, they are stored within the program, at the bottom. Therefore, if you want to share regular positions, you have to copy the data from one program to another (in the same robot) or load the program from one robot into another.
Position Register PR[ # ] are Global, and can be used by all programs in that robot. Usually, data that is Global, will be stored in a VR file.
I hope this helps to clarify some,
MI Robot Guy
