Need info on an laser area sensor that is easy to setup and use with a fanuc system
Fanuc DCS area sensor
kevinh1234 -
April 13, 2019 at 10:49 PM -
Perhaps you can elaborate your question a bit. I am assuming you are asking about compatibility of area sensor with Fanuc Robot having DCS option.
Ideally, you can go for area sensor of any make. Doesn't make a difference for the robot to use them because at the end all you need from that area sensor is an input (24/0V through NO/NC).
