Roboguide External I/O Connection mapping
  • Samuel De Smet
  • April 10, 2019 at 4:09 PM
  • Samuel De Smet
    HI,
    I want to read the UO from the Roboguide
    Therefore i set up a OPC communication between my PLC and the Roboguide. I can map ( and read them out in the PLC ) the first 16 UO to a word but the 17 and up gives me a red field box (see attachment)
    Any help is more then appreciated!
    Sam
    Images
      • 65.76 kB
      • 772 × 491
      • 146
    Files
    mapping.jpg_thumb 12.32 kB – 376 Downloads
  • Fabian Munoz
    133
    Articles
    1,517
    • April 10, 2019 at 8:42 PM
    hello Samuel
    Welcome to the robot forum
    I know nothing about OPC but I can tell you Fanuc doesn't have 32 UI so maybe that is the conflict
    Maybe you could do what is most common, which is map the UI to DI and then do your OPC comm
    Retired but still helping
  • Samuel De Smet
    • April 11, 2019 at 1:33 PM
    Thank you Fabian.
    I was indeed mapping two words into a 18bit long array. To solve this i linked a word to the first 16 UOP bits and the other two to booleans.
  • kikenavarro
    • March 3, 2020 at 12:29 PM
    Hi Samuel,
    Did you finally communicate through OPC? How do I have to configure the TP? and Kepserver? I need external I/O connection?
    I tried trying all the ways I've seen in the forum but it doesn't communicate.
    I work with roboguide v9 and kepserverEx 5 in the same virtual machine with 2 ethernet module.
    Thank you so much.
  • daffyhunden
    • March 10, 2020 at 7:31 AM
    Hi kikenavarro.
    What should you connect to Roboguide since you need the OPC? I can help you with the connection, but it depends on what you are trying to do?
    I have a physical Siemens S7-1200 PLC connected to Roboguide via KepserverEX and it works-
    daffyhunden
