Read and change register value from c# app using pcdk.
Limburger -
April 9, 2019 at 6:37 PM -
Check that *.Value has attribute write and has same data type as your number that you are trying to put in.
How check thas value? How write it correctly? How to assign a numeric value to the register? -
if you are using MSVS then you can move your cursor on .Value and it will show you the variable type - class name. Based on this information you can understand what you are working with.
