Looking at used amplifiers on eBay... How important are the last few digits in the part number? For instance, I need to replace an A16B-1100-0330/05B. Will my robot work if I put an A16B-1100-0330/04B in it? Significant potential savings on parts for an OLD robot...
Used Parts
droth -
April 1, 2019 at 1:26 PM -
The two cards you write can work interchangeably. It means that the version upgrade has been made only as a result of the structural changes of the electronic materials used. If your old card is working normally but you want to take action, you can recover the card by changing the group of bobbins on the mosfet group and the mosfer group. However, if your card does not pass the general tests from the first opening, it can be obtained by replacing the electronic materials with both battery and capacitor features on the card. If there is no light on your card and it is not working at all, the watt type in the power input section of the card is probably protected by a high resistance.
