Hello everyone. I generate one CAM program and i sent it to robot. But i cant run it. I got some fails. Can you help me for that? I attached error image
Nachi sending and running CAM program
fatal546 -
March 12, 2019 at 7:43 AM -
Most likely issue with Robot Language syntax .Maybe try compiling the Program in controller and check for errors
Maybe, you should tried to copy program with ext. memorty (usb).
After that, you should compile your program.
Service > ASCII File Edit > Select Program > Execute > Complete.
After that operation, you can see your program from directory. -
Have exactly same problem. Will tray knnklnc solution.
