Hello, I have a NX controler stuck in Maitenance mode.I haven`t any alarms. I checked a pendant cable and "Main Menu"button. Can someone give me some advise?
NX-100 stuck in maintenance mode
zdravkov -
March 11, 2019 at 7:12 PM -
Sounds like the controller lost its memory. Do you have a Memory Battery Weak Message? Do you have a cmos.bin to reload? If not, the system will need to be re-initialized.
I can't remember, it has been so long, and can't remember if it is on the NX or XRC but, there was a rotary switch on the front of the CPU that would boot to maintenance???? I absolutely cannot remember the settings....
Maybe 95 Devils can remember......
I'm old. I forgot. Thanks, Tony.
The NIF-01 board has a rotary switch that can be set to boot in Maintenance Mode. I believe that is a 5. Should be set to 0 on a single robot controller.
