Have a quick question here. Is there a way to map Outputs to other Outputs. So if I have four outputs that extend different cylinders can I mep it so I can use one output to extend all four at the sametime?
I/O
Noob1982 -
February 28, 2019 at 2:57 AM -
Yes, it can be done in the ladder. but you may need to brake out the bits from the groups they are in. (or BMOVs on DX)
Or if the outputs are in the same group you can do it binary.The CIO manual has the info that will help you with groups and BMOVs.
