Hello friends, i m working on LR mate 200iD, i don't find DCS in system it 's normaly Thank you
LR mate 200id DCS
Passionate -
February 19, 2019 at 2:35 PM -
Do you mean the DCS menu is not present on the pendant?
If not, you will have to install the option in order to use it. -
I activated DCS in variables, DCS is present in the pendant now, but i have only 4 options when i go in
DCS, i have 1 Safe I/O consistency check
2 Safe I/O Device
3 Signature number
4 code number setupI explain to you, i will to create a security enclosure, all i know is that i have to go in DCS then Check position, or no ?? do you have any ideas ?
If memory serves me correctly, in order to create safe zones you'll need the DCS Position and Speed Check option. It is possible that while you have DCS option(s) turned on, that you do not have this particular option enabled.
You can look in the pendant to see what's installed: MENU>STATUS>VERSION ID>F3 CONFIG
Scroll through the list and see if DCS Pos./Speed check J567 and DCS Safe I/O connect J568 are installed on your controller. -
yes it's true j567 and 568 are not present and how to install this option, I am new in robotiq, my boss is an integrator at fanuc but he's never present, I am generally alone, thank's for your help
If you want the options, you will have to contact Fanuc and get PAC codes so you can authorize and install them.
Ok thank you
Right. It’s part of the advanced DCS package.
Sent from my iPhone using Tapatalk
