Is there a way to capture a position(after searching using force) and then offset the robot from that captured position ? Like doing an LPOS or JPOS in FANUC robot.
Capture position to waypoint and then offset
Skipp -
February 1, 2019 at 4:19 PM -
You can use pose_trans() or pose_add() to convert a point. So if I had a pick point and wanted to offset that for an over pick position I could use those functions. If you want to move in the tool frame of reference then you would use pose_trans, pose_add is in the base frame of reference.
For example if I wanted my overpick to be 100 mm above the point in tool frame (assuming +Z is coming out of my tool)
var pick = somePose
var overPick = pose_trans(pick, p[0,0,-0.100,0,0,0])movel(overPick, a, v)
movel(pick, a, v)That would move to the overPick and to the pick point. You can also choose variable as the type of waypoint if you are using Polyscope.
Sent from my iPhone using Tapatalk
