Hi all,
I have a couple of welding program's with the S420iW with RJ2. A couple of the welding spots were a bit off, so I did Touchup for the points that need to be redone, most of the time a couple of mm down or up. So I do touchup and it says that it's recorded in the bottom and when I continue in the program it will go a little bit up and than back to the "new touched up" point. It is still in the same linenumber btw. If I redo this a couple of times the issue is gone.It does this by like 10% of the touched up points, and will sometimes hit the product in the process. Has anybody got the same issue and maybe a solution?
