Using Karel what would be the best way to monitor the W,P,R of a position register and if they change for some reason prevent the program from continuing?
Karel question
JRivard -
January 10, 2019 at 9:46 PM -
I wouldnt do it using KAREL i would just lock the position register using a lock command and monitor the position in BG logic and always write the correct position to it.
Thanks for the response Iprogram. Ive never used BG LOGIC before, how would I go about setting this up?
Also make sure whoever is using the robot knows not to run the Get_Home program. It will erase your PR:1
